    Model a membrane
    animate thicken membrane field
    7130
      Moving post here
      • target-photo
        target-photo last edited by
        Hi me again...
        imagine a zylinder r = 100 , hight = 5
        now I want do bend it like a membrane (border does not move)... how to do this?
        I tried it with a half sphere, animating G(y)... but this does not work well, because when thickness = 0, particles pass through...
        I need a cylinder with some thickness... can you help me again? Thank's Henri
          Hi Henri,
          Please no new question/themes in an existing forum's thread. Thank you. That helps to keep things searchable. 🙂
          Here is an example:
          CV4_2024_drs_24_MOmb_01.c4d
          The shape is based on the Remapping> Contour
          Let me know if that works for you.
          • target-photo
            • Referenced by  Dr. Sassi Dr. Sassi
              Henri,
              Here is an updated version based on the image you posted.
              CV4_2024_drs_24_MOmb_02.c4d
              • target-photo
                target-photo last edited by target-photo
                rehello
                perfect solution! The capacity is represented by the membrane (her tension is the voltage in my model)
                now I will animate the cylinder filed 0... 100 %
                please tell me what is the best way to bend in opposite direction ?
                ufff... i am such a beginner...
                Sorry animate the cylinder filed in the Displacer
                  Thanks for the extra information, Henri,
                  Here you go:
                  CV4_2024_drs_24_MOmb_03.c4d
                  Is this working for you?
                  • target-photo
                    soooooo cooooool
                    mille grazie
                      You're very welcome, Henri
                      È stato un piacere per me!
                      • target-photo
                        Hi again... need your help 😞
                        I used your membrane (03)... perfect... for new orientation, I did put all in a null and rotated it... all good... worked.
                        Then I pressed something in c4d, and now all my files do not work anymore. For the vertical membrane, the membrane center moves up and down... if I rotate the main null (membrane horizonaly)it works fine again.
                        I did not find out, what setting in c4d makes this mismatch... 😞
                        Please give me a hint 🙂
                        • target-photo
                            Hi Henri,
                            Please have a look here:
                            CV4_2024_drs_24_MOmb_04.c4d
                            I hope that helps.
                            • target-photo
                              1000 grazie! Works!
                              How is it possible, that it worked before... and suddenly in all files direction was on vertex normal ?
                              Have a nice day
                              Henri
                                Great, and thanks, Henri, for the feedback.
                                Vertex Normal. That is the default. If I had known that you like to rotate those, I would have pointed it out.
                                • target-photo
                                  Hi again
                                  this night I woke up and knew what was the problem... I updated to latest version of c4d!
                                  In the old version you could put the membrane in a nul and rotate this... still worked fine (with vertex normal default)...
                                  This changed in last version.
                                  @U
                                    Hi Henri,
                                    I had no idea you were in an older version of this project; that explains it – I assume, as I have no idea in which version you were, even now.
                                    I typically assume the current version is used, and yes, I should have asked for an example file, which allows me to see all that information.
                                    Thanks for solving that mystery.
                                    • target-photo
                                      now 2024.2.0... before 2024.1...
                                      buona notte
                                        Thank you very much, Henri.
                                        I will keep this in mind.
                                        Buona notte for you as well, it will take a while before I can call it a day.
