    vertex map edge
    • I
      importance-peak last edited by
      Hello 🙂 I'm having some troubles with the vertex maps and don't understand if I'm doing something wrong or or it s a bug. I get this stepping effect when adding a decay modifier on the edge of a growing vertex map. Any idea on why this happens? Thanks a lot
      PS: this is 2024.4 but tested in 2023 and the same
      alt text
      alt text
      • I
        https://we.tl/t-rCw5Alnz87 here s the scene I tested on made in 2024.4
        Thank you
          Hi importance-peak,
          Is this working better for your project?
          File
          https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_PROJECTS_DRS/20240430_CV4_2024_drs_24_ANvd_11.c4d.zip
          Preview
          https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2024_Clips_DRS/20240430_CV4_2024_drs_24_ANvd_11.mp4
          The Speed of the growth (Speed), the distance (Radius), and the line width (which was introduced with the Curve) need to agree; otherwise, it creates this "quantized effect" or stepping effect.
          I have also set the mesh density so that it produces squares.
          Please note the change of hierarchy (Position of the Curve).
          Is that matching your question?
          • I
            Hello Dr. Sassi,
            Yes, thank you for the explanation. It makes more sense now. I will pay more attention to these parameters.
              You're very welcome, importance-peak,
              But keep a copy of the stair-case-effect. It is a nice setup.
