    Vertex Map spreading
    • T
      table-state last edited by table-state
      Hi there,
      probably a pretty simple task, but I’m struggling a lot of setting this up.
      I have a rolling ball which leaves a trail through a plane with a vertex map.
      Is there an effector which can spread the trail behind the sphere a bit?
      alt text
      alt text
      Thanks a lot, I can also upload the scene file if that‘s more convenient.
      • T
        Hi, here‘s the scene file if it helps. Thanks a ton!
        https://www.dropbox.com/t/K7vmnBBmBtkZ4qWu
          Hi table-state,
          Thank you for the file. I will not send it back, as it is pretty large.
          Images work only 500 pixels vertically or less.
          If I get your idea correctly, the fastest way would be to use the Vertex Map and place it in the Field for Dampening Maps. Set the Value relatively high, like 500%.
          The perhaps more correct way would be via plastic Deformation, but I got faster and cleaner results with the dampening.
          https://help.maxon.net/c4d/2024/en-us/Default.htm#html/CLOTHTAG-CLOTH_PBD_PLASTIC_DEFORM_GROUP.html#CLOTH_PBD_BEND_PLASTIC_DEFORM
          I also tested other options, but the dampening seemed the fastest and easiest way.
          One would be to just use a Plain Effector (Switched to Point Deform) and use the Vertex map to deform it into place. See image. Not sure if the results are detailed enough.
