    Make stairs on a curved wall
    3763
    • C
      Capprim last edited by
      Hello!
      I'd like to make a group of stairs on a large curved wall. How can I do that? Thanks! JavierStairsToCurvedWall01.c4d
      • C
        The stairs in the scene sample are just reference. They can be modified. And they must be on the wall
          Hi Javier,
          Thanks for the file!
          I used your references without adjusting them to any typically used formula.
          (There is a formula that makes staircases easy to walk, 2h+1V=63cm)
          CV4_2025_drs_24_MOmg_01.c4d
          The Radius of the Cylinder is the number in the Radius of the Cloner. The outside part has a Radius plus the stair width.
          Or do you wanted is around the Cylinder?
          CV4_2025_drs_24_MOmg_11.c4d
          Is that working for you?
          • C
            Hello! Both are fine! But inside the cylinder.
            • C
              Adapted to the curved wall
              • C
                The curved version has several stairs. How can I make it a single one?
                  Hi Javier,
                  Is this what you are looking for?
                  CV4_2025_drs_24_MOmg_12.c4d
                  Enjoy your weekend
                  • C
                    Perfect! Thanks a lot!
                      I'm glad it works for you, Javier.
                      • C
                        Hello! I have another question related to the stairs. How can I make a curved, spline, handrail that goes from the top to the bottom? I'm having problems to get the exact shape of the stairs. See scene. Thanks!
                        CurvedStairsHandrail01.c4d
                          Hi Javier,
                          I see that as a similar question, typically new questions should be in a new thread, otherwise it is hard to search and read. Thank you.
                          Also: thanks for the file.
                          Here is a handrail that follows the Cloner Settings.
                          CV4_2025_drs_24_MOmg_31.c4d
                          New elements are marked "green" (Layers)
                          Let me know if that works for you.
                          • C
                            Hello! I see two problems in this solution; I'd like to make the handrail one single piece, like made of concrete. And I need to make another group of stairs shorter in the same cylinder. Besides I see many elements! So, is there no good option to make it simple, like the first sample I enclosed with helix & sweep? Thanks again!
                              Hi Javier,
                              The setup was designed to follow the staircase in case of a change.
                              That is no problem; here is the simplest way to create it, but any change on the stairs needs attention on its own.
                              CV4_2025_drs_24_MOmg_41.c4d
                              • C
                                The other one seemed too complex for me! Thanks a lot! That's done with it!
                                  Thank you very much for the reply, Javier.
                                  I'm glad we found what you like to have.
                                  My best wishes for your project!
