    Earth atmosphere help
    • M
      Motion_Shane last edited by
      I'm remastering a project I did for Space.com years ago.
      https://1drv.ms/v/s!AhqezjGsboVdhNouHbY4F8YmgHz06g?e=NnsUVj
      I've been following this tutorial on youtube (https://www.youtube.com/watch?v=3e_gGGJCpyU&t=674s) about how to create a realistic Earth using Redshift and Cinema 4D and I'm running into an issue with the texture of the Earth streaking through the atmosphere object like its passing through glass.
      https://1drv.ms/i/s!AhqezjGsboVdu-84sgJ7LWA6G2dHdQ?e=vbfls8
      I think I understand why it's doing it but I cannot for the life of me figure out a solution. Any suggestions?
      Here are the project files:
      https://1drv.ms/f/s!AhqezjGsboVduLcQ2QkI03CqJ2znIg?e=dmtGFl
        Hi Motion_Shane,
        I have created a little example; while the time slider sits on frame 55, I hope I got the best balance. Perhaps frame 48? Your idea might vary; please have a look between frames 0 and 96 at what could fit your scene. The key to fine-tuning it might be in the Fog-Curve and the light inside the Sphere> Details> Volume adjustment.
        CV4_2025_drs_24_RSea_01.c4d
        I got the scene, but it gives me a lot of error messages. Are you not getting any of these? If you don't mind, if there is a problem in the future, reduce the file to the core problem, which helps a lot. You might be familiar with your scene. Thank you.
        You might have a different setup.
        Please check with tech support if you get those error messages:
        One more favor to ask, could you please use the following cloud services for this forum: DropBox, Wetransfer, Google, Apple, or Adobe? One drive sometimes shows problems, and yes, it should be safe, but so far, the five above have shown to work all the time, and I stick with it for security reasons anyway.
        Enjoy your project
