    Data Smith file
    • Dutchbird
      Dutchbird last edited by
      Is it possible to export a C4D file with redshift textures as a data smith file?
      Cinema4D user since R8
      MacBookPro M1
        Hi Dutchbird,
        Do you have this in mind?
        https://support.maxon.net/hc/en-us/articles/4411492995730-Cineware-for-Unreal
        Make sure to have the latest Cineware plug in installed
        The two most fitting videos
        https://www.youtube.com/watch?v=OXWl81bsr70
        https://www.youtube.com/watch?v=m6W_vBoVbB8
        Is that what you are looking for?
        Dutchbird 1 Reply Last reply Reply Quote
        • Dutchbird
          Dutchbird @Dr. Sassi last edited by
          @Dr-Sassi I see. It must work. I have to try harder.
          I just exported a test file to my client but he can’t see the materials.
          Uv’s and geometry are okay.
          I’ll keep you informed.
          MacBookPro M1
            Hi Dutchbird,
            When you export, are the images included?
            Save As Cineware?
            I have too little data to say more.
            • Dutchbird
              @Dr-Sassi It all worked locally. I can export the project with all textures and import it in Unreal. No problem.
              But when I share the project with all assets and textures to the client he is getting problem with the textures.
              Now I exported the project as FBX with embedded textures and all is fine on the client side.
              MacBookPro M1
                Hi Dutchbird,
                When you re-open the exported files, is the path information local or global?
