    Progressive 360º+ rotation with sound
    mograph sound progressive rotation
    • S
      stretch-equal last edited by Dr. Sassi
      I try to make a simple 360° spinning with music.
      So I did a plain with a sound effect inside.
      A cloner with my mesh inside and the effector sound.
      I got a tiny rotation but it bounce back. Do you know how I can do a linear 360° continuous rotation without bouncing back ?
      Thanks in advance
      Best regards,
      ps / I Cant modify the subject ...
        Hi stretch-equal,
        Any reason to post in the Site Issue forum instead of the Q&A Forum?
        Please let me know. I will move this question soon the Q&A Forum.
        Anyway, since you are in a different time zone, I will wait.
        Please have a look here:
        CV4_2023_drs_23_MGge_01.c4d
        I have not shared an audio file, and I assume you have one.
        The idea is pretty simple; the Freeze layer can update the values per frame.
        So I have set the Sound layer to add a very small value. So it adds each beat a little bit to the overall result for individual Clones.
        (instead of that small value, disable the Value Clamping to be able to work with values above 100%)
        Since the value is small, the parameter for rotation needs to be larger. For demo reasons, I have added a P.Y. option, as rotation alone can be misleading. Please shut the P.R. in the Plain Effector off after you have explored the setup to get only rotation.
        IF you need something smoother, place a Delay over the Sound, set to Smooth.
        The Subject line should read. MoGraph, Progressive rotation via Sound? Would that fit your question? If so, I can change it.
        My best wishes
        • S
          Thanks you a lot !
          You just solve an incredible effect for a monumental art project.
          If I want to use it with 4 lights it's same configuration ?
          Best regards,
          Idd you can move the post to the right section, a mistake from me.
            Hi stretch-equal,
            Thanks for the feedback, and now I'm curious about the project. 🙂
            Here is the file with four lights.
            CV4_2023_drs_23_MGge_11.c4d
            I have set two child objects under the Cloner just to illustrate options.
            Also, in the middle of the timeline, I have set the Sound layer to subtract, just in case that might be useful.
            • Moved from Site Issues by  Dr. Sassi Dr. Sassi
            • Referenced by  S stretch-equal
