    Striped feather
    tech support
    • O
      OPS last edited by Dr. Sassi
      Hello!
      I'm trying to get the feather textured with horizontal stripes.
      I've followed this video on Cineversity:
      https://www.cineversity.com/vidplaytut/creating_a_feather/
      and added a Gradient Texture to the feather/hair material. However, I can't get the striped look when rendered on Redshift.
      Not sure what I'm doing wrong.
      Could you be kind and take a look at my file here?
      https://www.dropbox.com/s/4o6vflqx9vka1hc/featherColorTest_09_05_2023.c4d?dl=0
        Hi video-resource,
        It worked up to R26, not in 2023. The UV Feather selection seems to be of no use.
        You can check with tech support if you like.
        I will file a report.
        • O
          OPS last edited by
          Thank you @Dr-Sassi!
          That's good to know that the feather UV is actually broken in 2023.
          I thought I didn't set it up properly. Thank you for your feedback and filing the report.
          • O
            OPS last edited by
            I have just created a support ticket as well. Ticket ID##605775
              Hi video-resource; thanks for that.
              As I have mentioned, I have filled a report.
              So you might get a reply saying that this is a known problem. But yesterday, there was no record of such.
              I hope it is fixed ASAP.
              Sorry about the experience while learning, and being exposed to the uncertainty, if the tool, the tutorial, or something else is incorrect.
              • Referenced by  A assignment-brave
                Here is a workaround:
                CV4_2025_drs_25_RSfe_01.c4d
