    Shuffling Dynamic dominos
    bullet dynamics domino shuffle
    • J
      jacket-imagination last edited by Dr. Sassi
      Hey everyone ! Does anybody have any tips on how they would go about animating dynamic dominoes shuffling. I have a group of dominoes with a dynamic tag on top of a table with a collider tag. I tried moving them with the characters hands and collider, I also tried using a field force attached the hand bone but have no luck. any tips would help! Thank you
        Hi jacket-imagination,
        Is this close to what you like to have?
        CV4_2023_drs_23_DYds_01.c4d
        Or with some joints (I would use the whole character)
        CV4_2023_drs_23_DYds_02.c4d
        Enjoy your weekend
        • J
          Thank you Dr. Sassi !
          this is sort of what im looking for but i want the dominoes to stick to the table and not roll over each other
          here is my scene
          https://www.dropbox.com/s/o9bws2tc4xt2qip/scene%201.c4d?dl=0
          and heres an example of what i want to do @ 30 seconds
          https://www.youtube.com/watch?v=NO0V_xMu0cw&t=30s
            I moved your post; you had posted it in the Delta Robot thread.
            Here is a setup that might allow you to do what you like.
            https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_PROJECTS_DRS/20230529_CV4_2023_drs_23_DYds_12.c4d.zip
            The key parameters are:
            No friction, no gravity, and little bounce.
            This would lead to fast movements and endless trajectories once kicked.
            For that, I introduced the Friction Field and, in the Dynamic tag, set the Force_Dampening to a much higher value.
            I have cached it so you can see what I saw.
            I placed an object on them to keep the "Dominos" from jumping or flying.
            The hand is in this scene just a sphere. I could not post your scene as it is too big
            If you like to touch some Dominos and use them as a shuffle tool for a moment, you might take the dynamic of and animate a group that is under the hand in the scene, which would be a yellow Dominos.
            Set the steps (Project Settings > Bullet) higher.
            There is no option; consider reasonable setup and versioning times to put pressure with the hand on Dominos and slide them around.
            • J
              This is perfect! thank you
                Thanks a lot for the feedback, jacket-imagination.
                I explored your scene a bit, perhaps putting a polygon selection on the fingers, and used that to place via MoGraph Cloner little colliders.
                Let me know if there is anything else.
