    Displacement on low poly mesh ZBrush/Cinema4D
    zbrush cinema 4d redshift displacement subdivision
    • S
      sense-leather last edited by Dr. Sassi
      Hi Guys,
      I am attempting to rig a very low poly hand in Cinema4D, but I am having issues with smoothing. The subdivision surface and tessellation (object tag) overly constricts the geometry of the hand, altering the shape dramatically. This change in geometry also creates a pinching effect when I apply a displacement. ZBrush doesn't have an issue smoothing out the hand while preserving the geometry, but I cannot replicate that in Cinema 4D. Here is a screen shot: help-with-rig.jpg
        Hi sense-leather,
        The hand on the right looks quite different, stretched.
        As usual, images have very little information. Could you attach an example file with the displacement texture, perhaps with a render from ZBrush, so I can understand what you see and perhaps place some notes on the render that are important to you? I assume we all have our ideas of how things have to be.
        So far, I think it is safe not to use a SDS-object and RS Displacement (RS Tag) for the same object. Not that you mentioned that, but just in case.
