    Visualizing field force (or other force) vectors
    force filed visualization arrows
    • AlexC
      AlexC last edited by Dr. Sassi
      Hello
      I'm trying to achieve an effect that involved "visualizing" a turbulence field.
      I followed Noseman's tutorial on creating a pyro simulation on a candle wick, and everything is working ok (the resolution of the simulation is a bit blocky, but I can probably upres).
      I'd like to visualize the turbulence field that is touching the candle, a bit like what you see when you put down a force field, or like X-Particles visualizing tools for forces.
      Is there any way to do this with built-in tools? Could it be a particle sim that is affected by the turbulence but with some kind of arrow sprite?
      Thanks for any suggestions, here is my project file
      https://www.dropbox.com/scl/fi/jhaiz1ak7txdno4c1hn19/CandleKill_1.c4d?rlkey=2xif5ebza06tmv4z01p42hi6w&dl=0
        Hi AlexC,
        Not by default, and yes, that would be easy in X-Particles.
        How about this show here, leading to your desired particular effect?
        https://youtu.be/-cfrTOHHQzQ?si=RJvR0Orq4hdxxCmo&t=392
        https://help.maxon.net/c4d/2024/en-us/Default.htm#html/OFIELDFORCE.html?TocPath=Simulate%2520Menu%257CForces%257CField%2520Force%2520Object%257C_____0
          P.S.: This is the simplest way to showcase "turbulence" or, better, Animated Noise controlled via a Field.
          CV4_2024_drs_23_PAff_01.c4d
          • AlexC
            Thank you Sassi! Am going to dive into all this today
              You're very welcome, AlexC.
              Enjoy!
