    Importing from Maya
    import texture render
    • P
      piece-capital last edited by
      I wonder if somebody could help me please. I’ve recently bought Cinema 4D (after years of using Maya) but I now need to get all of my models into C4D and am having some problems.
      I tried exporting them as .fbx but when I add a texture the models end up with completely messed up geometry, there’s triangles jutting all over the place that cast odd shadows on the models. I also tried .obj but then the entire scene is just one object. I also tried .abc for animated scenes but some of the models appear to have a speckled appearance to them that wasn’t there before. If I view the model in the viewport it all appears to be okay.
      Also if I apply a texture to one part of an imported model it applies it to the entire model because it sees it as one object, how can I get it to see each element of a model separately?
      Also none of the imported models will render in Red Shift.
      Please can somebody help with this as I’ve got hundreds (if not thousands) of Maya models that I need to get into C4D.
      Thank you
        Hi pierce-capital,
        The Connection to other DCC apps is important to us.
        Sorry for the delay; I had a week off and checked only the Q&A and Help Forum. Admins typically ignore Q&A questions posted here, as those questions are misplaced.
        This is the site issue forum, and I can't find an entry you have problems signing in.
        Since you recently bought Cinema 4D, enabling access should be no problem. Please open a new post with your access problem.
        My tip: can you reimport the FBX to Maya to see what it has produced? Since Autodesk bought FilmBox ages ago, they have a proper working roundtrip. Hopefully, the result will allow us to solve this in case something has changed.
        https://help.autodesk.com/view/MAYAUL/2024/ENU/?guid=GUID-8B49D591-3B68-4D6C-8ABA-10C19C8E51DC
        Some people have good results with the DAE_FBX format, which (AFAIK) has a triangulated check box.
        Have you tried to use the Mesh> Cut> Untriangulate?
        The round trip in Cinema 4D 2024 works fine; no new triangles exist. Yes, I test constantly, as answering from memory is typically not up-to-date; things can change quickly.
        Or check with Support:
        • P
          Thank you for your reply. I did try triangulating the model but nothing happened at all.
          I also couldn't see a triangulated check box (although I'm using Maya 2016)
            Hi piece-capital,
            Did you mean un-triangulate, as triangulate would do nothing to an already triangulated object?
            I need to see a small file. I have no idea what Maya 2016 had as an export option.
            • P
              Sorry yes, I meant un-triangulate, it must have auto-corrected it.
              When you say you need a file do you mean a screenshot of the settings in Maya or an exported fbx file?
                Hi piece-capital,
                Thanks for asking!
                I need an example file that you want to import.
                Images or screen capture have very little information.
                A file works, or it doesn't. If it doesn't, it's time to figure out why. I'm happy to look into it.
                • Moved from Site Issues by  Dr. Sassi Dr. Sassi
