    What are these grey dots?
    • AlexC
      AlexC last edited by
      Sometimes when I import a model from Sketchup or other 3d packages, I end up having these small grey dots that appear. Sometimes they seem linked to actual geometry and are thus hard to delete.
      Not a huge deal, but I'd love to understand their purpose.
      Thanks!
      L 1 Reply Last reply Reply Quote
        Hi AlexC,
        I do not have a current SketchUp License. Would you mind sharing a file that causes this?
        • L
          leininger609 @AlexC last edited by
          @AlexC I have seen these too, and mostly they have been used in reference to a coordinate system. Allows multiple people to work on the same project and have exact placement on objects. I believe they end up as a Null when imported in Cinema
            Yes,leininger609,
            That might be a reason, but I love to see a file and give an exact reply.
            I try to avoid guessing here, which has worked well for nearly two decades.
            Thanks for your effort and contribution.
            • AlexC
              Sorry I missed that first message Sassi, here is the file
              https://www.dropbox.com/scl/fi/l390ygqhqr677rlrqi1jo/GreyDots.c4d?rlkey=uk9ed04o9bdv70fzomp28s4vo&dl=0
                Hi AlexC,
                Thanks for the file.
                In this case, and as suspected by leininger609, these are Nulls (There is no geometry that would show up in renderings—if there is geometry, it needs a different handling).
                If they annoy you, do the following, see the image:
                1 Click on the "Funnel" icon
                2 Double-click on the Null
                3 Set the "Shape" of the Null
                • AlexC
                  Thanks Sassi! Simple!
                    Thanks for the reply, AlexC.,
                    My best wishes
