    c4d thumbnail doesn't show on MacOS on a MBP
    77
    17697
      Hi philosophy-chemical,
      Please have a look here:
      https://discussions.apple.com/thread/255762577?sortBy=rank&page=1
      Add your vote please.
      In my private opinion, it seems like something Apple needs to address. Yes, there could be a workaround, but that might be eliminated when Apple fixes it. Meaning, all previews set up with an app based solution might miss the images then. This puts every non-Apple developer in a difficult position.
      Yes, having no solution after so many months is annoying; I agree.
      My best wishes.
      • Tisi
        Tisi @philosophy-chemical last edited by Dr. Sassi
        @philosophy-chemical Hi, yeah it's pretty sad this hasn't been fixed yet. Right now I need to search for some old Project files in my Archive, it's a joke because I have to open every file to check for it's contents. My workaround for now is to use Anchorpoint
        , a great project tool in general which has the ability to generate C4D Thumbnails for its own file view. Try not roll your eyes while digesting the fact that you have to use a third party tool to get thumbnails of your C4D files. Let me know if this works for you, hope I could at least ease the pain a bit.
        P 1 Reply Last reply Reply Quote
          Hi everyone,
          Please note that any 3rd party app suggested here in the forum from members doesn't mean that we test the app for security.
          This is at your own risk.
          • P
            philosophy-chemical @Tisi last edited by
            @Tisi said in c4d thumbnail doesn't show on MacOS on a MBP:
            Thank you very much, Anchorpoint seems to fill the gap
            • Tisi
              Tisi last edited by
              Update: no change here on my side with 2026.0.0 😔
                Yes, I know, Tisi, not fun.
                Please add to your Tech Support ticket – if I can at all ask for that extra work. I know patience is not endless.
                My influence is not inside Apple, where I suspect the main problem is.
                Again, sorry, and yes, it isn't very pleasant.
                My report for the file preview for 2026.0 is submitted.
                My best wishes
                Tisi 1 Reply Last reply Reply Quote
                • Tisi
                  Tisi @Dr. Sassi last edited by
                  @Dr-Sassi Thank you for your continuing support, it sure is appreciated.
                  • E
                    ericsiegel last edited by
                    Sigh ... Ticket SOLVED, Ticket CLOSED ... it makes no difference as there is a long pattern - I charitably assume due to engineering understaffing - in which features and functions are put into the application with incomplete or incorrect or scene-damaging functionality and then are allowed to languish literally FOR YEARS - through annual ticket refreshes - in a buggy state with little hope of repair unless enough "customers are affected". Adding new features is great - and I applaud Maxon for the great features it regularly rolls out to us - but fixing the features that are already in the application is also great.
                      Hi Tisi,
                      Thank you! I hope it is soon history. Fingers crossed.
                        Hi ericsiegel,
                        I have submitted this problem now three times, and yes, it is not OK that it takes that long.
                        Apple has EOL'd the way it was done before. It wasn't just the code line that was screwed up.
                        As you report your experience, I can only say, you should not have to face this pattern, and I'm truly sorry.
                        A pattern means to me at least three of those Solved-Closed, while there are no result cycles. Please share the ticket numbers, so I can ask the Tech Support Manager how that was possible.
                        Rest assured, as far as I can tell, we have the largest team of developers and tech Support ever, and based on our last Global Summit Meeting, there is a great energy and mood within each team. So, surely no shortage of talent.
                        • E
                          Some are just slightly annoying, others more-so, some I gave up re-filing ...
                          Ticket #714872 Text Height Incorrect … 2025 … persists in 2026 ... text objects are not created at the specified height
                          Ticket #681014, #277651, #215525 Auto Take <-> User Data Issue … CONFIRMED BUG S24 … persists in 2024 … persists in 2025 … persists in 2026 ... I use a lot of custom camera rigs that are controlled by User Data sliders. IF, while in AUTO TAKE mode ... you change the position in a Child Take using the USER DATA SLIDER, the Parent Take’s value gets changed also
                          Ticket #681007 + 681012, #277652, #215526 Watermark Large Text … CONFIRMED BUG ON MAC S24 … persists in 2024 … persists in 2025 … persists in 2026 ... Using large type sizes (>72) in Watermarks produces text that is cut off on the bottom.
                          Ticket #290379 Take Render Warnings … CONFIRMED BUG S26 … PERSISTS IN 2023.2.0 … Take Render Warnings appear even though all assets are accounted for in the Project Asset Inspector. Maxon Support claims it seems related to placing textures on Dropbox. The "Take Render Warnings" will appear when the following two conditions are met ... 1. Filenames are "localized" AND 2. The required textures are in subfolders of the "tex" folder, as is common in organizing scenes with many textures.
                          Ticket #277653, #194847 Photoshop Adjustment Layers Inside Groups Do Not Render … CONFIRMED BUG S24 … persists in 2023.2.0 … persists in 2026 ... Textures using Photoshop files with groups containing adjustment layers DO NOT render correctly IF THE GROUP IS SELECTED IN THE LAYERSET … the adjustment layers are ignored.
                            Thank you very much, ericsiegel.
                            I count eleven tickets that are not solved within a version cycle. This is annoying, no argument here at all.
                            Did I miss it? There is no Preview ticket, correct?
                            No idea if that is of any interest, but perhaps it saves some time to have that source:
                            https://support.maxon.net/hc/en-us/articles/8658038724124-Cinema-4D-2026-0-September-10-2025
                            I will share the ticket numbers along with the question, focusing on pattern detection.
                            Thanks again.
                            My best wishes
                              Hi Eric Siegel,
                              I went through all eleven reports/tickets. As far as I could, I have tried to recreate the setups; some had files redacted (an NDA was mentioned), so I couldn't.
                              Two things stand out: your reports are clear and fair, and the tech support replies mirror that. Thank you for staying so professional. With your long-time expertise in this field, it might be second nature for you anyway to work on that high level. Nevertheless, thank you.
                              The common message I found was that the Tech Support team did everything they could to move it forward to the developers and shared as much information as they were able to.
                              The common ground here is that both sides understand what is needed, wanted, or possible (which doesn't mean they agree or consider it favorable), but some things are not moving forward.
                              That bugs me that more tickets get the attention is a common practice, but keeping something for too long is not cool, I get that.
                              OFFTOPIC (Regarding File Preview)
                              With anything below, I might mention things that you already know, and you might roll your eyes at me for even bringing it up. I have seen your website, and I have no derogatory thoughts on my mind here; if that comes across as such, I apologize, as that was not my intention.
                              As I mentioned, I went through some of the steps, but I was unable to reproduce the user Data/take problem; it worked fine. [2026.0/Mac]
                              The Height in the Text parameter does not match the Coordinates Size numbers manager; there, I found an answer that could have cleared the situation. My perspective is that one shows the object's dimensions, the other the type height.
                              The Watermark is annoying, and nope, this is not OK.
                              The Text in the lower part is cut; I miss the files, sorry, no idea.
                              Photoshop Files with adjustment layers; here, I would suggest something different than a decade ago. Color management-based. Whatever you adjust here might not look the same in another colorspace. Wild geusss here here - as I have no examples from the report/ticket. I have been using OpenEXR for over a decade, and if possible, I already work in the final Color Space.
                              Besides, when I merge layers in Photoshop, they often produce weird things – in Photoshop itself, and that has been the case for a very long time. I've been using Photoshop for in my forth decade now, and I love it, but it has its limits. I wouldn't expect any third-party app using PS files to process large setups better than PS itself—my two cents.
                              I haven't found any File Preview mentioned in the Ticket Numbers, but you made your point clearly; some things are delayed for too long.
                              I hope that you can see that we care, and my exploration today has shown me that the File-Preview feature has received more attention internally than others. I hope that we find something that will work across platforms and, as much as possible, be backward compatible.
                              Thank you very much for your tremendous effort with the ticket numbers.
                              My best wishes
                              • B
                                bike-disaster last edited by
                                hello again! is there any update about the Quick Look issue in newest MacOs.
                                I ask this in google AI
                                is the Quick Look for .c4d files work in Tahoe?
                                No, the standard Quick Look functionality for .c4d files does not work in macOS Tahoe (macOS 16).
                                The native Quick Look generator plugin included with Cinema 4D uses an older file format (.qlgenerator) that is incompatible with recent macOS changes introduced in Sequoia and continued in Tahoe.
                                Current Status on macOS Tahoe
                                Quick Look (Space Bar Preview): Pressing the space bar on a .c4d file will likely only show a large generic icon or no preview, rather than a render of the 3D scene.
                                Icon Previews (Thumbnails): Similarly, Finder thumbnail previews are generally broken, and you will see a default application icon instead of a preview of the file's content.
                                Potential Solutions
                                Maxon is aware of these compatibility issues with newer macOS versions and is expected to release an updated Quick Look extension (using the modern App Extension format required by Apple) in a future software update.
                                Until Maxon releases an official fix:
                                Ensure "Show icon preview" is enabled: Check Finder View Options for the folder to ensure thumbnail generation is requested by the OS.
                                Keep Cinema 4D updated: Ensure you have the latest version of Cinema 4D installed via the Maxon App, as a fix will come through an update.
                                Check System Settings: You can look in System Settings > Privacy & Security > Extensions > Quick Look to see if any Maxon options appear, but they are unlikely to function correctly if they are using the old format.
                                  Hi bike-disaster,
                                  Thanks for pushing. If I see more options to support this, I will do so, of course.
                                  I surely feel it as well, and it is not fun when searching through thousands of C4D files that I got since this problem occurred, especially when most people do not share with simple naming convention.
                                  The problem is clear, and yes, the solution is eagerly wanted.
                                  To toss out just something that works now and fails soon, with the next OS update again, is not how I would love to see it.
                                  I do not see anything new in the AI report. Gemini is surely not my first choice in AI after testing it with a few hundred deep researches over a long time, comparing it to a few others, the fantasy it has, and its ignorance of preferences stands out in my selections of AI entities: I mention that, as I have written a lot of feedback to Google; I surely feel when a problem seems to make no progress.
                                  I have reported all problems with the preview, shared where I can. Adding anything to this thread at this point will have little effect. What is effective is using the tech support! That is the most powerful option right now.
                                  Please use the tech support options.
                                  • W
                                    whereas-stuff last edited by
                                    Are there any news on this? It's soooooooo annoying!
                                    Other companies managed also to have a fix for this.
                                    Please, share this important "bug" again. How long shall we wait?
                                    • P
                                      philosophy-chemical @whereas-stuff last edited by
                                      @whereas-stuff I started this thread in oct 2024 -- I'd had the issue for I think like 6 months prior. Much more than 2 years have passed, and despite the fact I've given this company thousands of dollars, an extremely and critically important UI feature still remains unresolved.
                                      I've given up expecting a solution -- I have been using Anchorpoint instead, which was suggested by another user in this thread. It's not super pleasant, but it kinda gets you there 40% of the way.
                                      B 1 Reply Last reply Reply Quote
                                      • B
                                        It's a shame that such a large company doesn't consider its customers who pay many thousands of dollars. It also makes a clear distinction between Windows customers and Mac customers. Obviously it's based on the fact that, they don't run away to go to the blender. Great shame, 2 years now.
                                        • B
                                          this is the answer form tech support
                                          Thank you for reaching out to us and sorry for the issues you are experiencing while using our software.
                                          I'm sorry, this problem is not yet resolved and it may take some time. However, I will forward your information to our development department.
                                          Please read this information on how to handle errors and the difference between troubleshooting and technical support:
                                          Due to the nature of software development and testing,
                                          We are unable to offer any dates or time frames on product releases, updates, or bug fixes.
                                          This allows our development teams to remain flexible in addressing priorities,
                                          And ensures that they have the time needed to produce the best products and find the best solutions for our creative user community.
                                          Please feel free to check our Maxon release notes page for information on all current releases as they become available.
                                          We will be closing this Support ticket, but it does not mean that we are closing the bug ticket.
                                          For more information on this, please see the FAQ: Bug Reporting, Fixing and Feedback
                                          I'm sorry for this inconvenience.
                                          Kind regards,
                                          Jörn Gollob
                                          Cinema 4D Technical Support
                                          • B
                                            bike-disaster @philosophy-chemical last edited by
                                            hi , I try anchor but I can't find all the files in external drives , maybe is something I am doing wrong.
                                            I figure out another solution, I install an VM on parallels with Sonoma , just instal a R25 without licensing it, and I can see from there the thumbnails when I need.
                                            any way from the answer from technical support I don't see any solution from Maxon soon. maybe they need group lawsuit from the Mac users 😛 for discrimination because we pay the same amount of money with windows users
