    Candy bar break, two questions.
    vfx animation mograph voronoi
    • O
      object-kind last edited by Dr. Sassi
      Two questions:
      I'm trying to rotate the two pieces of the candy bar (on the X and Y axis) just after it breaks apart. Currently a Voronoi fracture is making this happen, but its on just one piece of Geo.
      Would I need two pieces of Geo with opposite sides?
      The other question is, how do I control where the Voronoi fracture is effecting the bar. For an example, if I wanted a thin membrane around the outer edge of the the bar not to be effected by the Voronoi fracture.
      https://www.dropbox.com/s/o3tkucxkiv4cicy/Screen%20Shot%202023-01-05%20at%201.27.19%20PM.png?dl=0
      I have copied a DB link to a .C4D zipped file below.
      https://www.dropbox.com/s/eu5o1wrol3dymda/Candy%20bar%20BREAK.c4d.zip?dl=0
      Thanks in advance!!!
        Hi object-kind,
        Yes, I would make a copy and set each other half as invisible. Example:
        https://www.dropbox.com/s/foh5bimsd57nq3x/CV4_2023_drs_22_MGvf_01.c4d.zip?dl=0
        The idea of Voronoi Fracture Glue comes to mind, perhaps as an alternative, have a look here:
        https://www.dropbox.com/s/vuwmhjcbwtgn8hd/CV4_2023_drs_22_MGvf_11.c4d.zip?dl=0
        A thin membrane would be an extra object.
        Perhaps even make it editable and use the Optimize function.
          P.S.:
          https://www.dropbox.com/s/p679n753ln1796r/CV4_2023_drs_22_MGvf_02.c4d.zip?dl=0
            Perhaps switch off the standard Point Source, as the Cube provides enough data.
            https://www.dropbox.com/s/y0k9f22tnhwzr8x/CV4_2023_drs_22_MGvf_03.c4d.zip?dl=0
            • O
              Thank you!!
              These are great examples! It's gonna take me a while to understand how the Mograph tag has been assigned to the left and right side of the bar.
              Thank you Dr. Sassi
              And thank you for the other file you replied to (the string and ornament)!!!
                You're very welcome, object-kind.
                Let me know if you have a question; I'm happy to look into it.
                The later version is perhaps the easiest to work with for this setup.
                The core here is in the "Glue" section of the Voronoi Fracture.
