    How to animate a pre-designed pattern using mograph effectors?
    cloner mograph effectors vectorobject c4d
    • A
      ASeifried last edited by
      I'm working with a massive, pre-designed vector pattern. I want to use effectors for the animation and I'd like to keep the pattern in its original layout.
      I used a cloner object set to "Object" mode to get individual movement on the clones with a plain effector, but it redistributes the clones, breaking the design. Everything else I've tried sees the pattern as a single clone.
      What step am I missing here?
        Hi ASeifried,
        Typically I need a project file; images don't tell me much.
        Images often give me more questions than anything else.
        So, this might work or not, as I miss data.
        Place all of your objects under the Fracture Object.
        This should not change anything in your setup.
        Now explore the options with Efectors and Fields, etc.
        • A
          ASeifried last edited by ASeifried
          Hi Dr. Sassi!
          Thanks for the quick response. Throwing the shapes in the Fracture object worked out well! The only other element I need to figure out is how to retain the original colors of the shapes. I'll go ahead a post a project file so that you can see what I'm talking about.
          Project File
            I will leave this upload link for a few hours.
            https://www.dropbox.com/request/TGs1TrmWNdLYQqGSju1S
            Typically a small file (zipped) can be uploaded here in the forum.
            Sorry, I do not know the URL you use, and I strictly use only here Adobe, Google, Apple, Wetransfer, and of course, Dropbox as cloud services. Shortened URLs, also not to my taste.
            I share so many files that I can't take risks. Yes, I'm sure you are confident with this service, but I don't know.
              Hi ASeifried.
              Here is an example I hope it matches your idea:
              https://www.dropbox.com/s/4nmkuub4hgwuorm/CV4_2023_drs_23_MGrp_01.c4d.zip?dl=0
              The Material solution is pretty simple; each object has a material applied. I'm unaware of what render engine you use, but it works in all Native Cinema 4D versions.
              Please note that I have placed a non-connected point to the triangle shapes to move the virtual axis. That helps to have the axis not on top of each other. Otherwise, the two triangles that create a cube have the same axis position.
              Please let me know how that works for you.
              A 1 Reply Last reply Reply Quote
              • A
                ASeifried @Dr. Sassi last edited by
                @Dr-Sassi Thanks again! This worked well!
                  Thanks a lot, ASeifried, for the feedback. Very much appreciated.
