    Cloner shaped by Spline
    mograph honeycomp shape spline wall
    33555
      Hi smckenzie,
      Thanks for the file. Please have a look here:
      https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_PROJECTS_DRS/CV4_2023_drs_23_MGrt_31.c4d.zip
      This is pretty much a summary of some comments from above.
      Please note that I have set the work plane to that part of the roof to the orientation of three points (selected) of that roof. Things are more accessible that way. (Reset it by Workplane to Y)
      https://help.maxon.net/c4d/2023/en-us/Default.htm#html/51902.html#PLUGIN_CMD_1027593
      I have used the Edge Spline to harvest the left and right boundary and the outline of that roof side.
      In that way, the "half" end pieces were quickly defined.
      The two planes under the Connector Object (also mentioned earlier) are slightly shifted to each other; in that way, they create the shift while layered.
      The Clones are Multi Instances, which will save a lot of rendertime.
      Roof material has a different shape, and the "cubes" are easy to adjust to practical sizes. Just in case someone reading along find them not realistic. 😉 they are just simple proxies/examples.
      Enjoy
      • S
        smckenzie last edited by
        Thanks for this, glad to see it can be done natively. I'd asked around for nearly a year and your the first person to show a solution 🙂
        That being said, this would be a slow workflow with multiple roofs.
        These guys made this plugin some time ago - how is this working?
        https://www.c4dzone.com/en/shop/plug-ins-17/tuile-generator-2-0-10-108.htm
          Thank you, smckenzie,
          If you want something for a roof that is automated, the plugin looks great, but they have not shown a single round shape; how about a bat dormer or a little round Cone-shaped roof? As before, I'm not here to evaluate plugins, especially those I don't have. You need to get it, test it in your environment, and explore if it delivers what you need.
          I had the plugin bug in the '90s and spent $10K on plugins. Most of them fed my ego but never made any money. The key is to explore if the solution is not establishing new problems (… does it works with external render farms). Like getting used to it, and it is no longer developed.
          It is always one tile, and the borders are not based on specific end "stones".
          Please always check if the plugin supports the latest release. That would be my first indicator.
          Typically the details are done with Displacement if time is not provided to do the detailed work. Then it works like a decal. Very fast, and if the Materials are of good quality, you might have trouble seeing the difference. Of course, detail shots might unveil it.
          If there were a perfect solution for all shapes of roofs, walls etc., like a one-click option, who would hire a visualization artist anymore? We might get there, the more people push for simple options.
          Roof Tiles can also be distributed with textures (Shader Effector, Shader Field). Take your time and dive into MoGraph or Texture-based solutions.
          If you work on a feature film and details are shown, the character runs over a roof with a close-up of the shoes, then textures will not work as much as a model.
          • S
            Its for some of these reasons why I didn't get the plugin however up until no no one has been able to give me any other solution, especially a native one.
              Thanks for the feedback, smckenzie,
              I would encourage you to look into the Asset Browser of Cinema 4D. There are tons of materials. The image below is based on that.
              Or even explore Adobe's Substance offerings, which allows you to create unique surfacing options.
              https://www.adobe.com/products/substance3d-painter.html
              Elly's Quick Tip is a must-see, of course.
              https://www.youtube.com/watch?v=08CqyBVkpeU
              • Referenced by  Dr. Sassi Dr. Sassi
                Hi smckenzie, you started another thread with the same question, only with a more complex Spline, and about something that started the whole thread here.
                A complete shape-defining Spline will not be available. For example, splines will not create the needed "endcaps," even if they could shape the clones. (Splines can be used as "Knife".
                Another problem you get into with a Boole, the only option I can see here, is that (as mentioned) the Multi Instances will not work, as one can't shape single instances and expect them to be Multi-Instance based as before. Either or, never both.
                Shader-based or texture Alpha-based, same problem, the "cut" areas have no cover.
                Besides Boole, Volume Modeling is an option, but for roofs or walls, that is a little bit excessive and will lead to rendering times that are not wanted, I presume.
                If the clones are based on Polygons or Generators, (Sweep) doesn't matter. Spline can't limit it.
                Have you written "Share Your Ideas" to Maxon by now?
                • S
                  Although it was more complex and unlikely it would be possible, I just wanted to make sure I wasn't missing something.
                  I've experimented with most options including maps, Boole, displacement etc. I even tried RailClone on 3DSMax!
                  RailClone is clever and offers a lot of flexibility, however I don't want to be in 3DSMax land.
                  Fortunately for me, I found a copy of the NLinn shader, it's based on the original and the company I found had reached out to the originator of the shader and was given the original code. Anyway, I just tried it by making some planks in a cloner and generating a normal from it and it looks great. From there I'll generate a displacement map and just go that route.
                  I do really appreciate all the effort you put into my requests, I can't express how nice it is to have someone to ask questions and get a prompt response!
                    You're very welcome, smckenzie.
                    Please keep asking questions, as I believe that a problem comes back until it is solved. So, I try not to avoid anything here, and please never take my "moderation" (AKA keeping things organized) personally. New theme, new thread. Same question, old thread. Yes, yours was slightly different the second time; hard to find the right balance.
                    So far, I have answered Cinema 4D questions over 35,000 times in a Forum. The times I had to say there is no option (AFAIK) are very low. You can check even the past twelve years at Cineversity.com.
                    I'm sure that I do not know all, as I might find tomorrow a solution for something I was not aware of today. However, each question leads me to explore, and I'm under the impression that there is no failure, only gained experience. I assume I have some experience. 😉
                    So, I am happy to get your and other questions; they lead me to things I wouldn't have explored otherwise. I also try to understand the overall tendency and put this in discussions during our meetings into the mix. I try to be a voice for our members here, but please use the "Share Your Idea option; otherwise, I sound like someone who generalizes things without factual background. Thank you.
                    With that being said, I tried today several other options. But even if you use the path of the Sweep and cut that, the resulting shape with have straight edges in x, y, or z, per clone, staircase-like, not tilted as the spline asks for...
                    Here is a little example with a cube shape. I have left the problem in it. Move some points, and it is gone. A typical problem but easy to fix, even with nearly invisible changes.
                    https://stcineversityprod02.blob.core.windows.net/$web/Cineversity_Forum_Support/2023_PROJECTS_DRS/20230304_CV4_2023_drs_23_MObo_01.c4d.zip
