    Rotation Problem
    rotation axis
    4222
    • R
      Rough1 last edited by Dr. Sassi
      Im having a problem getting my head around what is, for sure, a very easy thing... I want to rotate an object in a circle, but have the bottom fixed at a point. Much like if you stuck a pencil in the ground, the moved the top around in a circle... ya know what I mean? The rotation would be cone shaped, not cylinder, Can someone help?
      Cheers, Simon
        Hi Simon,
        Please have a look here. The idea is to rotate a Null and have a child, Null being the one tilting the object.
        CV4_2023_drs_23_ANrr_01.c4d
        Is that working for you? If not, please share a demo file of that problem, just the object.
        R 1 Reply Last reply Reply Quote
        • R
          Rough1 @Dr. Sassi last edited by Rough1
          @Dr-Sassi
          Hi, and thanks again for your help... Unfortunately, it was not what I was trying to achieve, as the axis of the rotating object must always be pointing in the same direction. I have animated it by hand. It doesnt look so presise, but it'll do. Rough enough, good enough...
          Regards, Simon
            Hi rough1,
            Thanks for the feedback. A reason why I typically ask for a project file, which I missed here.
            Since leaving this open-ended here might not be pleasant for any reader of the forum, is this what would solve it?
            Is this coming closer? The Y-axis stays vertical.
            CV4_2023_drs_23_ANrr_02.c4d
            • R
              Yeah, sorry, the models I work with are CADs from our R&D department... They would flip if they thought I was sending them out of house, whatever the reason...
              Regards,
              Simon
                Hi Simon,
                Any Dummy with a polygon object will do. But if there is no time for that, that is OK.
                Please see my question here as well as a long-time investment, as it helps me with future questions to understand more about your work. Every artist is different, and as far as possible, I like to adjust my replies to it, while I over-share typically to address the needs of beginners as well.
                Have a great weekend.
                • R
                  @Dr-Sassi Hi sorry it took a bit of time, busy boy an all...
                  Here's how I achieved it, but with a few more keyframes to smooth it out a bit more. But It would of been much better to have the head move in a perfect circular motion, while keeping the same direction.
                  cheers,
                  Simon
                  Rotation Test.c4d
                    Thanks a lot, Simon.
                    Here is your file back.
                    CV4_2023_drs_23_ANar_01.c4d
                    or, less flexible, but see for your self:
                    CV4_2023_drs_23_ANar_11.c4d
                    I have introduced two parameters for a total of four keyframes. It moves perfectly round and as a loop for 0-120 frames.
                    The tilt can be adjusted.
                    Enjoy
                    • R
                      @Dr-Sassi AHHHH ha... Now I see.
                      Thanks for the help.
                      Simon
                        Hi Simon, you're very welcome.
                        It feels like "functions" could operate it (no keyframes!); perhaps XPresso is the way to set up something. I see a Cosine and Sine shape there 😉
                          P.S.: Here is an XPresso example
                          CV4_2023_drs_23_ANar_21.c4d
                          The Multiply Node is for speed adjustments.
                          BTW.: No keyframes needed!
                          Have fun
