    Material Projection.
    • R
      Rough1 last edited by
      Hi!
      Since the last update, I have noticed the default material projection is spherical, instead of UVW mapping. Can I change the default somehow?
      Thanks in advance
      Simon
        Hi Simon,
        I have checked it, and it has worked so far for me.
        For me, Spherical is only applied if the object has no UV data.
        Since you have a different result, all I can offer is to check out a file that you share. (Smaller than 1MB, and ".c4d" works here as a direct attachment)
        Just the one object that shows Sphereical as projection when the material is applied.
        • R
          Hi and thanks again for your help. Here is an object that is from a CAD file, imported as a .stp into C4D. IDK if its to do with the polygon arrangement, Ive never had this before. When you drop or apply a material, its always spherical projection by default. Well on my machine, anyway.
          Cheers, Simon
          DrSassi.c4d
            Thank you very much for the file, Simon.
            Here is your file back.
            CV2024_drs_24_TXuv_01.c4d
            Drag the Material on it. It should work fine now.
            It was missing the UV Tag.
            I dragged the Material on it, then went to the Object Manager> Tag> Generate UV W Coordinates.
            In the UV editor layout, all UV polygons were selected, and then in the lower left, UV Manager> Automatic> Cubic> Apply.
            I checked the Material again, and it worked.
            Let me know if you have any problems.
            R 1 Reply Last reply Reply Quote
            • R
              Rough1 @Dr. Sassi last edited by
              @Dr-Sassi 👍
                Thanks for the feedback, Rough1.
                Have a great weekend
