    How do I repeat a ramp pattern on an object using the texture node?
    9953
    • B
      bench-sport @Dr. Sassi last edited by
      @Dr-Sassi Wow! This UV Context Projection node is incredible! It's just the missing piece of the puzzle. I checked your file. Now, the MUL and MOD node isn't needed. That one context projection node is enough to do the work I guess!
        Hi bench-sport,
        Thank you very much for the feedback.
        You are spot on, and thanks for this insight.
        I was in the middle of QA and timestamping the news video, when this theme came up – I started thinking about your question.
        So, I checked it quickly, missing the extra advantage; I have a win as well, thank you!
        Have a great weekend.
        P.S.: https://www.youtube.com/live/ZAom6DvSi3s?si=8LscqDJJlmPROpnT&t=2956
        B 2 Replies Last reply Reply Quote
        • B
          @Dr-Sassi Thanks a lot for this! Life is easier now. 😄
          • B
            @Dr-Sassi Btw, I can't figure out How to do it for ring type outputs without using repetitive knots?
              Hi bench-sport,
              I assume I understand what you want, but that is not in the new Node included. Mul/Mod is the answer.
              Right mouse click on the Ramp allows for doubling the Knots and can be done many times. Yes, not parametrically.
              Here are three examples, and I assume they are not along your question, just to be on the safe side.
              One does example does it, but it is a hack, and not even.
              CV4_2025_drs_25_RScl_01.c4d
              If there is something else, I'm happy to look into it (in the morning)
              B 1 Reply Last reply Reply Quote
              • B
                @Dr-Sassi Thanks for the clarification.
                  You're very welcome, bench-sport.
                  My best wishes
                    @transition-worry - Post moved to
                    https://cineversity.forums.maxon.net/topic/2228/ramp-tiling-2026-1-uv-context-node
